reverse lights not working.
hi all , my reverse lights have stopped working , have checked fuse and bulbs they are ok. still nothing its a Berlingo multi space 54 plate 2ltr hdi. any advice on what to do next. thanks in advance.
Reversing light switch is on top of the transmission, but to get at it you'll need to remove battery & battery tray. The plug can then be removed from the switch - probably needs to be squeezed to get it to release. The switch should show continuity (if you have a meter) when reverse is selected. If not, then the switch, which is a plunger, can be unscrewed and replaced.
I don't know if the switch supply is a full 12v or whether it is a lower voltage signal to the Berlingo's brains, but either way you'll be looking for a supply to the switch when the ignition is on.
In addition to the above use a meter to check for voltage at the reverse light bulb connection : it is quick and easy and may save battery removal etc.
(01-05-2022, 12:58 PM)oilyrag Wrote:  Reversing light switch is on top of the transmission, but to get at it you'll need to remove battery & battery tray. The plug can then be removed from the switch - probably needs to be squeezed to get it to release. The switch should show continuity (if you have a meter) when reverse is selected. If not, then the switch, which is a plunger, can be unscrewed and replaced.
Removed battery and compartment but still cant find switch .
It is a Berlingo multi space 54 plate 2lt diesel.
Anymore help i would very much appreciate it.
Thanks, Paul
The red circle on the pic is (I hope!) the rev. light switch.  Ignore yellow arrow
(13-05-2022, 04:53 PM)oilyrag Wrote:  The red circle on the pic is (I hope!) the rev. light switch.  Ignore yellow arrow
thats as far as i got but dont know as cant see it lol.
As oilyrag photo shows, the switch is just beside the blue multiplug, the one near the frayed wire loom.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Maybe attach the blue plug to the reversing light switch????? Rolleyes
(13-05-2022, 08:39 PM)oilyrag Wrote:  Maybe attach the blue plug to the reversing light switch????? Rolleyes
the blur plug goes to something else , is the switch the grey one at the front pic attached.
Yellow arrow is switch. Should be continuity when reverse is engaged.
Leaking windscreen or aerial
Last Post: Guanajuato
Yesterday 09:05 PM
Apple Carplay
02-04-2026 01:26 PM
