USB set up to play music
Hello all
So this is my first car without a CD player... wanting to just digitise my CDs onto a big hard drive and play via USB.  But when I tested this, it says the USB device is not compatible and goes no further.  It's a USB3 device and format is MP3.  Has anyone managed to get music playing from a USB?
Martin
'22 Berlingo Flair XTR M 1.2 PureTech EAT8 with modutop
Ex '61 Berlingo Multispace XTR 1.6 HDi with modutop
2022-  Citroen Berlingo Puretech Flair XTR M Eat8 1.2 automatic petrol - Soft sand, with modutop
2011-2022 - Citroen Berlingo Multispace XTR 1.6 HDi manual diesel - Iron grey, with modutop
I've answered my own question... I had to re-format the drive, using a free piece of software, to FAT32 format. Now works a charm.
You have to re-format the drive to FAT32 format........errrr .......hang on minute.......
Now a 2019 K9 1.2 petrol.
[-] The following 1 user says Thank You to Mark604 for this post:
  • MartinCurtis
Once you start using it could you check if yours behaves the same way as mine - occasionally cuts out the source and plays FM for a few seconds, then continuing the MP3. Non-nav screen.
ex: 2003 1.4i cargo
(04-05-2022, 12:01 PM)boop Wrote:  Once you start using it could you check if yours behaves the same way as mine - occasionally cuts out the source and plays FM for a few seconds, then continuing the MP3. Non-nav screen.
I've not had that problem.
But I've had other issues with the meta tags on the tracks not being picked up by the car, despite amending them on my laptop.  I don't know if it's just going to take an age to sync as I put a lot on there.
Also - over 8,000 tracks on the hard drive, but seemingly only 5,000 listed on the car display.  I fear I may have stretched what Citroen intended for USB connected music.
[-] The following 1 user says Thank You to MartinCurtis for this post:
  • boop
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
