[Engine] fault p 1351
Hi!
I have a alarm lamp wich I have got diagnostic on. On the diagnostic it came up: p 1645. (driving speed limit void driving pedal value)
        p 1351. (glow relay)
        p 2137 (driving pedal posision signal comparison slow)
I have noticed that the glow light in dashboard has not been lit for a while and suspect that the glow relay can be the reason for this.
The car goes in to "emergency mode" when the lamp is lit.
Any idea if p 1351 could bee the most likely problem here?
Welcome!
I somehow doubt it's the glowplug warning causing your 'emergency' / 'limp' mode, the HDI engines will work ok without glowplugs but in a very cold climate like yours it's probably worth getting fixed. More likely is the other 2 warnings that hint there's a problem with the accelerator pedal. Do you have Cruise Control / Speed Limiter ? The reason I ask is that there are 2 different pedals, the speed limiter will only work with the correct pedal. If you have a search around, you should find the relevant posts, but if not, ask again.
Spot on Cancunia, the cruise control with limiter button only works with an accelerator pedal which needs to be marked L V V D (standard pedal is marked D)
@captain.nordvik, do you drive on the left side on Norway, or the correct (right) side as we do in the UK? I ask as the speed limiter pedal for a left hand drive would be L V V G (for Gauche / Left as opposed to Droite / Right)
limite voluntaire vitesse droite = LVVD = voluntary right speed limit (only referring to which side of the vehicle the driver sits)
Last Post: deejay_xb
Today 10:06 AM
» Replies: 32
XL tyres
Today 09:26 AM
Unusual Braking Problem
Today 07:57 AM
Outer cv boot replacement
Yesterday 10:13 PM
Yesterday 10:02 PM
Diagnostic Plug
Yesterday 09:55 PM
Yesterday 09:52 PM
Rumbling Noise 55-65mph
Yesterday 09:47 PM
Last Post: Beaumotor
21-03-2025 04:38 PM
engine light
21-03-2025 09:25 AM
