starter relay
My van wont start on the key, when turning key to start position i just get a clicking from in the under bonnet fuse box, the van starts fine if i cross the starter, where is the starter relay located? 09, b9, 1.6 90.
Is it a B9? I answered your post in the M59 section. What year is it? Prior to 2008, it's likely an M59 as they crossed over on 2008, after that year, it's a B9 (forgetting the newest K9 and the early M49)
There is no relay, it's an electronic module. Have a look at my reply to your other post, if it is not an M59 then let me know as I have to dig out different drawings.
Sorry its a b9, im new here didn't realised i was commenting on a m59 post.
Ok I'll take a look at the docs tomorrow at work. The fuse box is not that different but I have to check the drawings.
(09-05-2022, 07:54 PM)sky\s dad Wrote:  My van wont start on the key, when turning key to start position i just get a clicking from in the under bonnet fuse box, the van starts fine if i cross the starter, where is the starter relay located? 09, b9, 1.6 90.
What do you mean by, 'the van starts fine if I cross the starter?'
I assumed it meant by-passing the starter solenoid with a screwdriver ?
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Ok to the OP (Sky's Dad), here are the B9 engine bay fuse box layouts and fuse / relay list.
Fuse F8 in the engine bay is the starter motor 25A relay fuse (the location of the relay itself is secret) - check that first.
Today 01:49 PM
Yesterday 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
