Threads: 26
Thanks Received: 31 in 28 posts
Thanks Given: 9
9
Yup, sounds a bit sad.
But, when I accidentally tread the go & stop pedals at once on VAG cars,
the engine management comes up with a sensible guess & cuts the go pedal when the brake pedal is applied at the same time.
The 1.6hdi on my Partner (I know, I know) in the same situation assumes you really want to arrive at the accident.
Do your cars ignore the throttle if the brake is applied? (& I have a duff brake switch not talking to the engine management).
Thanks if you could let me know.
Threads: 43
Thanks Received: 410 in 367 posts
Thanks Given: 137
31
12-05-2022, 08:28 PM
(This post was last modified: 13-05-2022, 06:37 AM by brodfather11.
Edit Reason: edited about ignoring throttle
There have been a few times when pressing the brake i wonder who the hell is revving the head off their engine so you are not alone.
And no it does ignore the throttle.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 67
Thanks Given: 238
50
I just bent my pedals sideways to get more boot clearance ... sorted.
Serieal Berlingo owner
Threads: 26
Thanks Given: 9
9
Looks like a win for Volkswagen unfortunately.
It's about the only thing I really dislike about the Berlingo/ Partner.
Pity, as it would probably be a minor software update.
Looks like pedal adjustment is on the cards.
Threads: 29
Thanks Given: 67
20
It's only happened to me when I drove in my rigger boots so I avoid doing it by not driving in them.
Threads: 75
Thanks Received: 1,309 in 1,140 posts
Thanks Given: 223
164
13-05-2022, 08:25 AM
(This post was last modified: 13-05-2022, 08:27 AM by Sol.)
This is fixed on the B9, you can't touch the brake & throttle together or the throttle is cut to zero, as it should be on any drive by wire system (electronic pedal).
I would have thought the M59 would also be like this at least on the 1.6HDi, not so on the other engines with a cable throttle. Surprising to learn it doesn't.
Threads: 13
Thanks Given: 61
4
(13-05-2022, 08:25 AM)Zion Wrote: This is fixed on the B9, you can't touch the brake & throttle together or the throttle is cut to zero, as it should be on any drive by wire system (electronic pedal).
Gone are the days of "heel 'n toeing" then!
