[Warning Light] Airbag warning light
Is the comms unit the same for the airbag warning light?
F you have an airbag warning light problem on a M59 it is most likely one of the 2 connections under the driver's seat. They are rubbish and a known problem
Peter
what can I do?
It could also be a flimsy earth point behind the airbag. There are a few posts on the forum how to secure it properly.
I have a 2003 1.9D berlingo on and off airbag light tried a bypass resistor to find a dead short inside the ACU connector, these connectors are rubbish it takes a lot of fiddling to separate,  always dis connect battery and key in pocket avoid accidentally energizing your airbag as a punch can kill if not sat in seat with headrest on, anyone had the same problem?.??
(13-05-2022, 07:40 PM)Squad Wrote:  Is the comms unit the same for the airbag warning light?
On my 2003 berlingo tha coms unit ACU is on floor between gearstick and handbreak
https://www.google.com/url?sa=t&source=w...vJT3px7QOI
the thing that people are telling me I already know
A bit more detail on the question might help then.
If you post a one-line vague question (which comms unit do you mean for example) then people might be able to answer in a more specific way. What is the actual problem and what have you tried, etc.
Today 01:49 PM
Yesterday 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
