Hi, just wondering if anyone has had any experience with the accelerator not responding? Van always starts, after starting, within minutes (sometimes seconds) if you press the accelerator nothing happens at all. Always usually after first starting/ setting off. After a few minutes it carries on as normal like nothing has happened. Doesn't do it all the time but has started doing it more frequently now.
Can't seem to find anything specifically on this issue after searching the web. Any advice appreciated. Thanks
P.s Also worth noting I have ran OBDII scanner and got P1351 & P3007 codes if that helps anyone in their potential diagnosis.
