Threads: 9
Thanks Given: 2
I took the citroen cd player out and installed a Pioneer double din dab radio.
Now I cant access the menu to change the date and as I ve had the battery off this and the date are now flashing all the time.
Any thoughts? Ive looked right through Diag and cant see anything missing....
regards,
Steve
2014 B9 1.6 HDI Multispace.
Threads: 5
Thanks Received: 50 in 38 posts
Thanks Given: 19
6
To make it work you have to install Canbus adapter. Such an adapter required each time you replace the original radio by any aftermarket radio. Then you can access the menu from the stalk under the steering wheel.
The adapter that everyone puts in is Connectis2, look it up on Ebay.
Threads: 9
Thanks Given: 2
Ive got a coonect 1 on it, is that why its not working?
Threads: 13
Thanks Given: 61
4
Probably.
