29-05-2022, 06:12 PM
(This post was last modified: 29-05-2022, 06:14 PM by kingy1912.
Edit Reason: Mistake
Hi everyone,
Currently having issues with high coolant pressure and disappearing coolant. There is no smoke or steam evident from the exhaust just disappearing coolant and high pressure. Don’t notice any bubbles feeding back up the system but the header tank was replaced due to oil cooler leak. The inside of the tank is darkened and has a black film inside of it. When rubbed off it looks suspiciously like exhaust soot but the coolant does not really have a smell of exhaust gas coming from it.
Garage were the first ones to mention it as we found a leak in the hose coming from the header tank. Hose was replaced but still coolant disappears. We have now noticed coolant leaking from the seal on the radiator degassing hose that plugs in to the header tank. I suspect this is simply because of the higher pressure in the system.
Garage suggest an engine overhaul is best and I would normally agree but it has 370k on it and not long to go until we need to move it on.
I am currently swaying with using some of the KSeal Uktimate in it. However the overwhelming number of reviews are positive but there is a number of them suggesting it either made their problems worse or blocked their hoses and matrix up.
I am wondering if anyone has used the stuff in the HDI engines and know how it reacts?? I’m thinking that maybe a full bottle is too much for some coolant systems and folk are having issues because there is too much in the system?
Also seen steel seal but the reviews look worse for that.
