Indicator stalk
    What is the auto button on the end of indicator stalk for? Can't find any mention of it in the manual.
Automatic illumination of headlights.  Idea
I wonder if you can retrofit this
(06-06-2022, 12:50 PM)benoliver999 Wrote:  I wonder if you can retrofit this
IIRC, it uses a light sensor behind the mirror so while it's possible, I doubt  that it's easy.
I had the auto rain & light options on an M59, to be honest it did not work that well. You can find some posts on here about it being dangerous.
Not entirely surprised at this!
I thought I'd seen something about this somewhere....
https://www.peugeotforums.com/threads/re...as.357714/
https://www.peugeotforums.com/threads/au...or.340904/
Have fun!
Had a play tonight and the button doesn't seem to do anything ?
(06-06-2022, 11:08 PM)captainbugwash Wrote:  Had a play tonight and the button doesn't seem to do anything ?
I don't have my M59 handbook any more so can't tell you the correct page to look at. But from memory, if you press & hold that button for about 10 seconds you should see a message on the main display in the centre of the dash about auto lights being activated / deactivated. It may be that the ignition needs to be on or maybe off for it to work.
It may also be that at some point the stalks were replaced.
I think that @jj9 has an M59 with this function
Today 05:30 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
20-10-2026 06:45 PM
» Replies: 45
18-10-2026 06:46 AM
» Replies: 82
