Thanks Received: 1 in 1 posts
Hi folks.
Got a 2013 1.6 HDI Berlingo van and looking to do the rear disks n pads. Anyone know the size of the torx bit for the calliper bracket and the size of the hub nut?
Looks as though you need to replace hub nut too. Is this correct?
Cheers
Roger
Threads: 29
Thanks Received: 14 in 13 posts
Thanks Given: 4
Maybe an E16 spanner will fit the caliper bolts. No need to touch the hub bolt / driveshaft nut when doing disks and pads.
Threads: 8
Thanks Given: 305
36
The Rear discs require the hub nut to be removed as the disc is part of the hub.
The video shows the procedure and the tools required are listed in the description.
https://www.youtube.com/watch?v=j6KF_mSv3zQ
• cancunia
Threads: 123
Thanks Given: 250
34
They do good videos, shame about the prices (at least for the parts that I've looked up!).
Threads: 8
Thanks Given: 305
36
Yes they do good clear videos.
I've no experience of buying from them as like you say some of the prices seem a bit steep.
Threads: 8
Thanks Given: 305
36
The M59 versions did have the rear disc separate to the hub, my car has rear discs and the discs are separate.
I think all B9 versions have the hub/disc rears, it's also more expensive to replace them as the hub has the wheel bearing, so you're paying for the whole lot instead of just a new disc.
Threads: 75
Thanks Given: 223
164
13-06-2022, 07:04 PM
(This post was last modified: 13-06-2022, 07:05 PM by Sol.)
Spot on JJ.
Also the wheel bearing is the abs trigger, so you have to do the lot if either the bearing, abs or disc needs changing.
• jj9
Hi mThanks fur the replies.
To answer my own post now that I have done it.
Hub nut is 36mm
Brake caliper is 13mm Socket and 15mm spanner to hold the slider pin.
Brake caliper bracket is T50 torx
The following 1 user says Thank You to Jollyroger for this post:1 user says Thank You to Jollyroger for this post
• jj9
