Unknown alert noise
Lock Hi I have a 2005 2.0 hdi desire it has started to make a noise from behind the centre heater vents it sounds like a siren warning it is very irritating has anyone else experienced this it’s intermittent and can sound at any time
check heater fan bushings or dirt accumulated near the fan blades
If you like gaming visit GameForest
[-] The following 1 user says Thank You to deejay_xb for this post:
  • Davistosh
Possibly a door/tailgate switch thinking that the door isn't fully shut? More of a long beep than a siren though...... Rolleyes
  • Davistosh
heater fan is a simple check, just turn the fan off (0 speed) and if the siren sound is still audible then you have other issue..
  • Davistosh
Post your Ghetto Fabrication / Modifications "Ph...
Last Post: Kokain
Today 12:26 PM
» Replies: 38
Horn not working
Today 12:04 PM
Berlingo digital cluster speedometer upgrade
Last Post: kaktusas
Yesterday 02:48 PM
Cruise control retrofit
14-12-2025 09:37 PM
14-12-2025 01:33 PM
14-12-2025 12:49 PM
14-12-2025 12:00 PM
Anti Pollution fault warning
14-12-2025 11:39 AM
An almost Hydrolock in a DV6B
Last Post: chrisl
14-12-2025 09:36 AM
Last Post: chrisl
14-12-2025 09:27 AM
