Brighter reversing lights
Threads: 12
Thanks Received: 27 in 21 posts
Thanks Given: 31
Has anyone upgraded to LED reversing light bulbs?
Mine are terrible as standard, must be down to the tinted light cluster it has.
Are these LED replacements any better, don't want to spend the cash then find they're no good.
Threads: 21
Thanks Received: 36 in 34 posts
Thanks Given: 6
Later spec rear lights would help
The following 1 user says Thank You to muply for this post:1 user says Thank You to muply for this post
• 800HDI
Threads: 32
Thanks Given: 24
As Muply says, later ones would help, but not much I think.
I'm not convinced LED's would be much use either, it seems to me that they are bright but they don't always have the "strength" of light of normal lamps - the light doesn't seem to project as far.
I fitted an aftermarket reversing light in addition, but whilst it helped it has now rotted out.
The following 1 user says Thank You to Coco for this post:1 user says Thank You to Coco for this post
• 800HDI
Threads: 20
Thanks Received: 57 in 41 posts
Thanks Given: 33
LED bulbs will not give the same amount of light as normal bulbs as the LED's are more directional,whereas normal bulbs will give an 'all round' light.
You can either update the rearlights to the later spec,fit an additional reversing lamp or perhaps fit a halogen bulb.
If you do go down the LED bulb route then go for the smd type,the older oval type are even less use.
Threads: 101
Thanks Received: 276 in 220 posts
Thanks Given: 384
I had these on previous Vauxhall Combo.
http://www.ebay.co.uk/itm/24-LED-REVERSE...41514bdb6c
They were suprisingly good!
Let the van go with them fitted. Oops!
Not bought another pair yet, but would recommend.
The following 1 user says Thank You to j90xxx for this post:1 user says Thank You to j90xxx for this post
• 800HDI
Threads: 5
Thanks Received: 2 in 2 posts
(04-02-2012, 02:47 PM)800HDI Wrote: Has anyone upgraded to LED reversing light bulbs?
If you go online to Autobulbs they have a terrific range of LED bulbs, on my B9 model May 2008 Multispace VTR I replaced front side lights,rear stop/Tail,rear fogs lamps & reversing lamp bulbs they are a lot brighter would highly recommend did not change rear indicators as it involved splicing the wires to add a resistor instead fitted upgraded bulbs which give the appearance off being silver, I also upgraded headlamp bulbs to Ring 120% brighter but they are street legal well worth doing .
Threads: 17
Thanks Received: 117 in 92 posts
Thanks Given: 153
One point worth mentioning is that the MK2 rear light clusters have relatively small holes for the bulbs to fit through. Most LED lights I have seen are quite large in diameter, Will they fit into the cluster?
Has anyone replaced theirs yet?
Threads: 20
Thanks Given: 33
(04-02-2012, 06:12 PM)caravancrazy Wrote: (04-02-2012, 02:47 PM)800HDI Wrote: Has anyone upgraded to LED reversing light bulbs?
There is a fleabay shop called Blaize Electronics,they sell a replacement flasher unit for £16.00 so you can use LED indicator bulbs without having to fit resistors.
Threads: 63
Thanks Given: 410
(04-02-2012, 09:16 PM)XTR Wrote: (04-02-2012, 06:12 PM)caravancrazy Wrote: (04-02-2012, 02:47 PM)800HDI Wrote: Has anyone upgraded to LED reversing light bulbs?
Thought the Berlingo didn't have a descrete flasher unit and that the indicaters were wired through COM2000 or similar???
Threads: 101
Thanks Given: 384
(04-02-2012, 09:05 PM)adam3rdcanvey Wrote: One point worth mentioning is that the MK2 rear light clusters have relatively small holes for the bulbs to fit through. Most LED lights I have seen are quite large in diameter, Will they fit into the cluster?
I have 42 SMD LED stop tail bulbs. They fitted ok.
Today 04:24 PM
» Replies: 35
Last Post: Vlad
Today 02:36 PM
Yesterday 10:29 PM
Limp mode, no other symptoms.
Last Post: KiwiMurfy
Yesterday 10:33 AM
Nearside Headlamp bulb change
10-06-2025 01:59 PM
Barn Doors - Lockign Mechanism HELP?
10-06-2025 07:13 AM
09-06-2025 06:25 AM
» Replies: 34
Sump, Any good swear words?
04-06-2025 12:34 PM
6 speed gearbox conversion
Last Post: xtrmark
03-06-2025 05:29 AM
» Replies: 39
Part of Dipstick Stuck
01-06-2025 10:43 AM
