Threads: 54
Thanks Received: 81 in 75 posts
Thanks Given: 147
7
People correct me if I'm wrong here but
The first three pictures look like the folding wedge to put behind the wheel on the ground when you jack the other side up. It should be located in the underfloor storage underneath the passenger seat with the jack, wheel wrench, towing eye, centre cap removal tool and locking wheelnut key (if fitted) and they all click into a plastic frame.
The fourth picture seems to be of the two plastic retainers for the drivers loose floormat, these should be retained in the fixed carpet so that the loose carpet can click onto them, prevents the loose mat from sliding up under the pedals.
Matt
previous
2016 1.6 HDi 100 XTR Grey Met
2010 1.6 HDi 105 XTR Gold Met
Threads: 75
Thanks Given: 223
164
21-06-2022, 11:38 AM
(This post was last modified: 21-06-2022, 11:40 AM by Sol.)
The last ones are plugs for example to keep the flimsy hardboard panel on the inside of the rear door(s) - they push in and then the T shaped bit pushes closed, to lock them in place by expanding the lower plug section. Removing them is the reverse, lift up the T shaped part then pry the round head out.
The following 2 users say Thank You to Sol for this post:2 users say Thank You to Sol for this post
• Lawrence, Matt Haigh
Threads: 3
Thanks Given: 5
Sorry for the late reply.
Many thanks for this.
I'll go to investigate...
All best wishes,
Lawrence
Lawrence
2022 1.2 PureTech Flair XTR XL S/S EAT8
