2019 Berlingo 1.6 RPM
Hi all, looking at getting a 2019 1.6 Berlingo Diesel but noticed they only have 5 gears. Are they fine for motorway driving or do they end up with high rpm without a 6th gear when at 70mph?
Thanks Cool
aprox 2400 rpm at 130km/h, not high in my opinion
If you like gaming visit GameForest
As above. The engine develops max torque at 1750 rpm and maximum BHP at 3500 rpm, so the 70mph/2400 cruising speed puts the engine in the sweet spot where it still has the guts to overtake or climb long inclines without resorting to gear changing.
They are fine, you can pack up and ride fearlessly on highway in my opinion, I have driven at 85 MPH on highway 3 months ago. I had this same fear of not driven on the highway for the past 6 months then I finally decided to give it a try. It was success. :-)
On highway I usually do 140-150km/h, max I was 160km/h, no problem cruising at 150 Smile just keep an eye on Waze for cops/radars Smile)
Like you, I did question whether I should opt for a 6spd model multispace, those higher power models are less common. So now I've got my 3rd 5-speed Berlingo and I needn't have worried, the engine noise isn't excessive at 80-85mph and the K9 model I've got now is a lot quieter than the B9's I've had before. I also wondered if the 6-speed gearbox would offer better fuel efficiency, it may but my 5-speed is doing 51-54mpg over a range of journey types
Matt
   previous
   2016 1.6 HDi 100 XTR Grey Met
   2010 1.6 HDi 105 XTR Gold Met
Most of my driving is done on cruise control where my B9 and my sisters K9 are both happy enough at motorway speeds*
(01-07-2022, 11:09 PM)Matt Haigh Wrote:  Like you, I did question whether I should opt for a 6spd model multispace, those higher power models are less common. So now I've got my 3rd 5-speed Berlingo and I needn't have worried, the engine noise isn't excessive at 80-85mph and the K9 model I've got now is a lot quieter than the B9's I've had before. I also wondered if the 6-speed gearbox would offer better fuel efficiency, it may but my 5-speed is doing 51-54mpg over a range of journey types
At 80-85mph on foreign roads  Big Grin
Thanks for the reply all - Is this the same for both the 75bhp and 100bhp? (Assume the 100 is the engine to get). Thanks again
Yep.
Today 02:32 PM
Berlingo 2026
Last Post: xtimex
Today 05:06 AM
Yesterday 12:15 AM
Yesterday 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
Weird Air in Fuel Problem
Last Post: tomhick024
27-06-2026 03:25 PM
