04-07-2022, 06:05 PM
Hi I've got this warning message on the dash and it's usually taking couple of goes to start however sometimes it starts ok?
I've replaced the batteries in both keys and replaced the transponder coil ring on the ignition barrel but still same.
Strange thing after replacing the coil car wouldn't start so with ignition on pressed the unlock button on key several times and then it started??
Also now when I unlock the car and hold the button the windows open (common on most cars) but never did this before and does not close windows when holding lock button.
So I'm wondering if there's a way to clear the message without diagnostic equipment or a procedure to relearn system so it starts every time?
2009 Berlingo 1.6 hdi xtr.
