[Transmission] Clutch?
VF77JNFUC67605718
2008 Berlingo b9 with 1.6, 16v petrol engine with a 5 speed gearbox.
Can the experts in the group help with which clutch set I need and any other possible part/ parts needed.
Replies received with thanks
Ps: part Numbers would be great.
Have look here....  http://www.catcar.info/citroen/?lang=en
  • Gpr
Find europarts quite good . Put your reg in. Sometimes more than one option ,but has worked for me in the past.
Invariably the clutch will come as a complete kit of pressure plate, driven plate and release bearing - it is usually cheaper and easier to source the parts required for the job as a kit. Something like this https://www.auto-ricambi.eu/clutch-kit-c...mm-p50831/
As above from JJ9 & Oilyrag, the catcar site with a VIN input will lead to some part numbers for clutch kits, if you search for those part numbers you'll see a fair number of online suppliers.
There is also a guide tube on the B9 clutch, mine required replacing last year as it had seized and the clutch was a nightmare to operate, screaming when pressed and not much better when not pressed.
It cost me £400 to get a wee "clutch man" one-man-band to do it, my trusted local garage were too busy but quoted just shy of £1400 if they had been able to fit me in. A B9 is not a 5 minute job to change the clutch on.
Several other garages when called, quoted the same price as my local and all said there is a lot of labour on that vehicle to replace the clutch.
  • Gpr
Thanks for all your advise and links. The clutch seams a little bit grabby and not smooth in its operation
That could just be the clutch cable - given the cost and work involved in changing the whole clutch, fitting a new cable might resolve the issue for relatively little expense. If your clutch isn't slipping or making any odd noises you might also want to look at engine/gearbox rubber mounts as a possible issue too, again relatively low cost/easy fit options.
I'd call the cable as the cause, but until it's changed nobody knows!!
The B9 clutch is hydraulic mate.
Ha! I knew that really, just wanted to see if you picked it up! Big Grin
There seem to be lots of people selling cables for them, all the same.
Engine Fan Running
04-12-2025 11:07 AM
Last Post: SonofaGun
02-12-2025 10:51 PM
02-12-2025 06:14 PM
Rear view mirror
02-12-2025 08:19 AM
Gear number display
Last Post: MarcoLingo
29-11-2025 09:02 AM
25-11-2025 04:20 PM
Lapik's 5-th Berlingo
25-11-2025 08:21 AM
ë
24-11-2025 09:08 PM
Welding precautions
24-11-2025 12:37 PM
driveshaft tripod joint spring
24-11-2025 12:31 PM
