backup water tank, water level sensor diagram
Threads: 2
Thanks Received: 2 in 1 posts
07-07-2022, 02:52 AM
Hello everyone. My car is a 2004 peugeot partner. There is a sensor location in my spare water tank. but there is no sensor and power line. With lexia we opened this menu (engine coolant detection). But I can't use this feature because there is no installation. Where can I get this installation? Is there a relevant schematic? Looks like it will most likely be from bsm. Anyone who knows can help?
Threads: 61
Thanks Given: 234
29
If I were you with the Pug Partner, I would not be using Lexia, but PP2000. I have tried Lexia on my pug partner and it actually works, but some options are missing and some of the things cannot be done via Lexia.
Threads: 2
Hello there. I think I wrote it wrong. yes, we activated it with pp2000. but for this i need to install plumbing. This requires a schema.
Threads: 61
Thanks Given: 234
29
(08-07-2022, 02:29 PM)murattuzun35 Wrote: Hello there. I think I wrote it wrong. yes, we activated it with pp2000. but for this i need to install plumbing. This requires a schema.
Not too sure what you mean by a spare water tank, but you can download CEDRE which should give you various schematics.
Threads: 2
I solved the problem. its equipment is ready. Behind the headlight is a plug connected to the chassis. There are 3 pins. I bought a sensor and saw that the socket is compatible with it. I connected the socket to the sensor. and it is working. thank you very much.
Threads: 123
Thanks Given: 250
34
09-07-2022, 04:19 PM
(This post was last modified: 09-07-2022, 04:21 PM by cancunia.)
Interesting!
How do you know it is working / what does it do or tell you?
@ saskak, I think this is for the expansion tank?
https://www.ebay.co.uk/itm/222473451182
Threads: 43
Thanks Received: 416 in 373 posts
Thanks Given: 139
33
Would it be a tank for spare water (expansion tank?) rather than a spare tank for water
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 2
(09-07-2022, 05:34 PM)erkek baba11 Wrote: Yedek su deposu yerine yedek su deposu (genleşme deposu?)
I am sorry. I'm using translate. There may be a translation error.
Threads: 2
(09-07-2022, 04:19 PM)cancunia Wrote: İlginç!
Çalıştığını nasıl anlarsınız / ne yapar veya size söyler?
@saskak, sanırım bu genleşme tankı için mi?
I burned the engine twice. My heater pipe burst. the water in the system has run out. I didn't realize it because there was no warning system. The temperature was also constant at 90 degrees. to prevent such situations. If there is less water in the system, the warning and stop lamps are on.
Threads: 61
Thanks Given: 234
29
09-07-2022, 10:38 PM
(This post was last modified: 09-07-2022, 10:40 PM by saskak.)
(09-07-2022, 10:13 PM)murattuzun35 Wrote: (09-07-2022, 04:19 PM)cancunia Wrote: İlginç!
I can see clearly now (no pun intended). I suspect you mean you ran out of coolant twice. If the temp was a constant 90C then it was all good. Not too goood, but still the engine did not overheat.
I have not myself ran out of coolant, so cannot quite comment if my M59 has a sensor for the level of coolant. Good to hear you have installed one, although where did you plug it in and did you activate it via Diagbox/PP2000/Lexia?
Aha, thanks @ cancunia for the link, I have not seen that sensor around my coolant piping, but I do check my coolant level every so often.
Yesterday 08:36 AM
» Replies: 15
Last Post: Dyane6
02-11-2026 11:10 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
