Steering wheel radio control wire colours.
Threads: 2
08-07-2022, 10:14 AM
(This post was last modified: 08-07-2022, 10:47 AM by Dennis T.)
Hi, I'm Dennis T, from North Yorkshire England.Thank you for allowing me to be a member of your forum. I own a 2018 Citroen Belingo 1.6 hdi it has been converted so it can carry my electric wheelchair.
I am hoping someone came direct me to the right place.
My problem is I fitted a new 2din radio one of these touch screen ones. I had to cut the original car connection off as the new one didn't fit. I have managed to get working but need help with the steering wheel radio controls. Can anyone tell me the colours of the car wires from the steering wheel control to the radio.
Once again thank you.
Threads: 75
Thanks Given: 223
164
14-07-2022, 08:59 AM
(This post was last modified: 14-07-2022, 09:14 AM by Sol.)
Hi Dennis, welcome to the forum.
The steering wheel controls are VANBUS and not just wired to the stereo itself, the button conveys control messages to the OEM stereo over the VANBUS system and it in turn, responds. Once you remove the original stereo the controls no longer work, unless you fit a CONNECTS2 interface to add the functionality back again, search google for a CONNECTS2 stockist and speak to them, letting them know your head unit model and car details.
I've added the schematics of the stereo and steering wheel controls for your info, but you may not be able to make use of this with a non oem stereo as said above.
Stereo Main:
Stereo Main RD45.pdf (Size: 194.1 KB / Downloads: 40)
Stereo Full System:
Stereo (RD45 MP3) Schematic.pdf (Size: 282.88 KB / Downloads: 26)
Steering Wheel Controls: (CV00)
Steering Controls.pdf (Size: 91.03 KB / Downloads: 40)
Harness Plugs under steering:
Steering Control Plugs.pdf (Size: 182.25 KB / Downloads: 33)
Colour Codes: (Inc. VAN & CAN)
legende.pdf (Size: 73.37 KB / Downloads: 27)
Threads: 2
(08-07-2022, 10:14 AM)Dennis T Wrote: Hi, I'm Dennis T, from North Yorkshire England.Thank you for allowing me to be a member of your forum. I own a 2018 Citroen Belingo 1.6 hdi it has been converted so it can carry my electric wheelchair.
Threads: 2
Zion thank you very much for this helpful information.
Threads: 75
Thanks Given: 223
164
Hi Dennis, you're very welcome. I hope it works out for you, let us know how you get on?
Threads: 2
Hi ,Zion thank you for your help if I manage to sort it I will let you know.
Threads: 7
Thanks Received: 6 in 6 posts
Thanks Given: 50
Hi Dennis - can't help you with the wiring but hopefully you'll get sorted with Zion's useful information.
Let us know how you get on please.
And welcome to the forum. I'm quite new on here myself, and enjoying it very much.
Cheers. Vivian
First: M49 Forte (Petrol)
Then: B9 XTR (Diesel)
Now: K9 Plus with Style Pack (Petrol)
Threads: 2
(14-07-2022, 08:59 AM)Zion Wrote: Hi Dennis, welcome to the forum.
Stereo Main:
Stereo Full System:
Hi Zion. I have a question. I've added the steering controls myself. Got the...however...I see there is a Grey plug and a black plug on the steering column control module. On my B9 the black plug is not connecter and there is nowhere to connect it. Could that make that the steering controls won't work? If so would it be possible to just replace the control module with one that has the black plug present?
Threads: 75
Thanks Given: 223
164
That could mean you have a different com2000 module in the steering column without the audio stalk function, they aren't coded so can be swapped for a com2000 unit which has the plug.
It's the entire unit with the stalks already mounted normally that you would fit.
However you have to code the stereo to respond to the stalk controls using Diagbox, which is only possible with the factory stereo and vehicles up to 2015. After that model year, it can't be done except by DIY means, using pirated Diagbox as it no longer is able to do coding of functions.
Today 12:33 PM
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
