Beeping Radio
Threads: 43
Thanks Received: 2 in 2 posts
Thanks Given: 28
08-07-2022, 02:45 PM
(This post was last modified: 12-07-2022, 02:55 PM by Squad.)
Hi, does anyone know what can cause a Clarion RD3-01 car stereo CD head Unit PU 2471A(J) to beep? both the radio and cd plays but it still beeps.
Threads: 75
Thanks Received: 1,306 in 1,140 posts
Thanks Given: 223
164
Not sure, you might have to scan it with Diagbox to really find out. Could be a low level issue with the radio or signal from the antenna.
Threads: 8
Thanks Received: 499 in 448 posts
Thanks Given: 305
33
I'm guessing it's a 2nd hand replacement radio so the beeping means it requires coding to the vehicle, I think the VIN of the vehicle it is now fitted to will need to be entered into the radio via diagbox.
Threads: 26
Thanks Received: 31 in 28 posts
Thanks Given: 8
9
(13-07-2022, 05:27 PM)jj9 Wrote: I'm guessing it's a 2nd hand replacement radio so the beeping means it requires coding to the vehicle, I think the VIN of the vehicle it is now fitted to will need to be entered into the radio via diagbox.
Is it that simple to enable a 2nd hand radio?
I had assumed that if the radio didn't see it's VIN from the vehicle,
it then wouldn't cooperate with Lexia, PP2000 etc.
I'd be delighted if I was wrong.
220,00 miles, (Resurrected at 186,000)
Threads: 75
Thanks Given: 223
164
You only need to code the VIN into the new radio from your own vehicle details. It will connect fine to DiagBox etc, it will just flag a fault as incorrect VIN match until programmed.
Threads: 43
Thanks Given: 28
(22-07-2022, 01:54 PM)Zion Wrote: You only need to code the VIN into the new radio from your own vehicle details. It will connect fine to DiagBox etc, it will just flag a fault as incorrect VIN match until programmed.
Yes I know, but I'm not paying £70 just to get it decoded.
Threads: 75
Thanks Given: 223
164
Don't you already have Lexia/Diagbox/PP?
I thought I saw that you did, so it wouldn't cost anything if so. If not, Diagbox doesn't cost £70 or at least it didn't used to on eBay.
Threads: 43
Thanks Given: 28
(22-07-2022, 03:59 PM)Zion Wrote: Don't you already have Lexia/Diagbox/PP?
I thought I saw that you did, so it wouldn't cost anything if so. If not, Diagbox doesn't cost £70 or at least it didn't used to on eBay. No I don't have Lexia/Diagbox/PP, plus the £70 is for me to take to someone.
Threads: 75
Thanks Given: 223
164
22-07-2022, 08:54 PM
(This post was last modified: 22-07-2022, 08:56 PM by Sol.)
Much cheaper to buy Diagbox then as it's about £50 (if you hunt eBay) and you have it forever to do other stuff.
Here's a kit at £54.95:
https://www.ebay.co.uk/itm/155079047924?...media=COPY
Or...put up with the beeps!!
Your choice, we can only advise.
Threads: 8
Thanks Given: 305
33
(22-07-2022, 08:02 AM)smutts Wrote: Is it that simple to enable a 2nd hand radio?
Video of it being done... https://www.youtube.com/watch?v=FxXSuchLj8E
Or you could give this a try... just remove a small component...
https://www.digital-kaos.co.uk/forums/sh...1A(G)-CODE
M59 unlocking itself
05-11-2025 04:06 PM
04-11-2025 09:48 PM
04-11-2025 09:15 PM
horn
03-11-2025 08:41 PM
How many miles
03-11-2025 08:12 PM
03-11-2025 08:08 PM
02-11-2025 07:53 PM
Boot liner with 7 seats
31-10-2025 07:57 PM
Last Post: Buki
31-10-2025 07:26 PM
31-10-2025 03:06 AM
» Replies: 40
