K9 Sliding Side Door Problem
Anyone else had this problem/know the solution?
While pulling handle forward to shut NSR sliding door from fully open position, the handle moves forward/outward slightly, and in doing so  touches and pulls out the trim on the front fixed part of the door handle leaving it unclipped and likely to fall off. It clicks back in place easily.
I've made a short video to illustrate the problem.
K9 NSR Door Problem
Matt
   previous
   2016 1.6 HDi 100 XTR Grey Met
   2010 1.6 HDi 105 XTR Gold Met
Yes. I had mine glued to place by the dealer.
ex: 2003 1.4i cargo
[-] The following 1 user says Thank You to boop for this post:
  • Matt Haigh
Mine does thaton the drivers side door
Peter
[-] The following 1 user says Thank You to Romahomepete for this post:
  • Matt Haigh
Not had that problem at all. But I note that in your video you pull the handle out and then slide it - mine just slides quite happily without pulling the handle out.
2020  1.5 Blue HDi 130 Berlingo XTR
2009  1.5 Diesel Peugeot Partner
2007  1.5 Diesel Berlingo Desire
2003  Petrol Berlingo
[-] The following 1 user says Thank You to Desdinova for this post:
  • Matt Haigh
(12-07-2022, 06:40 PM)Desdinova Wrote:  Not had that problem at all. But I note that in your video you pull the handle out and then slide it - mine just slides quite happily without pulling the handle out.
Interesting, does yours both open AND close without pulling the handle out, please?
Matt
   previous
I have to pull the handle out first, I also had to do the same on the 2 B9s that we had. That is how the lock mechanism unlatches
Peter
Nope, to open you have to pull the handle out. But closing it just slides, there is slight resistance from the latching mechanism but it just slides past that.
I see what Desdinova means, when opening the door, you pull out and back, away from the trim. When closing, you don't pull the handle, just slide it shut with enough force to unlatch and then close it.
My B9 was the same as he describes, the K9 must be the same. No pulling the handle out when closing, otherwise you're pulling it towards the trim and out when closing and that is probably what is dislodging the trim cap. Just slide it from the open position with enough force and it unlatches by itself.
The cover comes loose when opening the door
Peter
Hmmm ok, not so good then eh. Maybe there's a bit of fouling from poor molding, maybe a fine file on the edge of the cover would help to stop it catching.
MOT Emissions repeated fail
Last Post: Marsaday
Today 10:41 AM
Rear door filling with water
Last Post: Marsaday
22-01-2026 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
