Eolys leaking ?
Threads: 6
Thanks Received: 3 in 3 posts
Noticed a pool of what like oil under the car but had a reddish tint. The leak is on drivers side about halfway along rear door, I’ve taken a photo but not posted pics on here before.
Checked all fluid tanks and all ok, nothing in the in car diagnostics.
Unfortunately not at home and will require just over 20 miles to get there.
First question..
Can I drive the car without any problems?
I think I have the tank version rather than the pouch.
I’d rather go to my Indy garage to get it repaired but might have to go local if I can’t drive.
Sorry for a not fluid post.
Berlingo 1.6 hdi 2009
2009 1.6HDI with AC
Threads: 68
Thanks Received: 1,183 in 1,049 posts
Thanks Given: 194
149
13-07-2022, 08:22 PM
(This post was last modified: 13-07-2022, 08:45 PM by Zion.)
On 2009 you will have a pouch system if it actually has a DPF. It just lives inside a tank-looking cover just ahead of the drivers side rear wheel if so. Pouches were still in use on my 2012 van. Your year is on the turning point I think, to even have a DPF at all so if not, no pouch OR tank. Could be wrong of course.
I'd expect you to get 20 miles without any issues if it is an eolys leak. It doesn't know how much is left so it can't detect a leak. Maybe this isn't eolys, hard to say. Power steering fluid or ATF sounds more likely from the colour as eolys is kind of yellowy from what I've seen.
Threads: 6
13-07-2022, 08:41 PM
(This post was last modified: 13-07-2022, 08:42 PM by magoo1.
Edit Reason: Atf
(13-07-2022, 08:22 PM)Zion Wrote: On 2009 you will have a pouch system if it actually has a DPF. It just lives inside a tank-looking cover just ahead of the drivers side rear wheel if so. Pouches were still in use on my 2012 van. Your year is on the turning point I think, to even have a DPF at all so if not, no pouch OR tank.
I'd expect you to get 20 miles without any issues. It doesn't know how much is left so it can't detect a leak. Maybe this isn't eolys, hard to say. Power steering fluid or ATF sounds more likely from the colour as eolys is kind of yellowy from what I've seen.
Thanks, def have eolys as it was refilled not long ago, ( as not at home to see invoice) have to phone garage tomorrow as they hopefully will be able to tell me. Then a question of when they can look at it.
Got just under half a tank of diesel.
The important thing is I can drive as long as I don’t take fuel cap off if I understand correctly.
What
Hats ATF?
2009 1.6HDI with AC
Threads: 68
Thanks Given: 194
149
13-07-2022, 08:49 PM
(This post was last modified: 13-07-2022, 08:50 PM by Zion.)
ATF is automatic transmission fluid, used in power steering and auto gear boxes. It's red.
It would try and squirt a shot of eolys into the fuel tank if you open the fuel tank cap so probably won't notice either way. If there was no fluid left in the pouch then it just won't be able to regenerate as well as it used to. But it will still run with no issues unless your DPF was near to blocking.
Eolys only helps to increase the DPF heating during regens and reduce Nox emissions. It has no effect on running.
Threads: 6
ATF is correct level.
Going to drive to derby for garage to have a look but can’t say when the job can be done until seen.
Thanks for your help it is much appreciated.
2009 1.6HDI with AC
Threads: 68
Thanks Given: 194
149
No worries buddy, best of luck with it.
Threads: 6
I will post once sorted.
2009 1.6HDI with AC
Threads: 6
At home now and found the invoice and I have the pouch, a new one was installed May 2021.
2009 1.6HDI with AC
Threads: 68
Thanks Given: 194
149
Ok good, so what mileage are you on now and what was it when the pouch was installed?
Threads: 6
20-07-2022, 11:48 AM
(This post was last modified: 20-07-2022, 11:49 AM by magoo1.)
(19-07-2022, 03:11 PM)Zion Wrote: Ok good, so what mileage are you on now and what was it when the pouch was installed?
99,990 miles now dpf fluid and pouch would have been about 90,000 miles, is a new pouch always fitted on a refill.
I raised the question about warranty and they are saying it's over year old but will check. My answer was the previous one had been there since built in 2009 so they should last longer than a year.
It's at the garage now, they also mentioned something about the might be pump leaking?
Will post an update later
2009 1.6HDI with AC
BSI
Last Post: Zion
Yesterday 06:47 PM
» Replies: 26
Dropped a valve ?
Last Post: james1089
Yesterday 05:34 PM
» Replies: 24
HELPPPPPPP, citroen extended warranty team rejec...
Yesterday 05:20 PM
Add blue / engine fault light
Yesterday 05:13 PM
Newbie
Last Post: Rosemerry
Yesterday 02:48 PM
Electric probs - where to start
Last Post: Zion
Yesterday 10:58 AM
Replacing wings
Yesterday 10:01 AM
Sliding door rattle
Last Post: melpa
Yesterday 12:57 AM
New to Berlingos - Impressed so far!
Last Post: RichCowell
29-09-2023 11:03 AM
Appropriate Jumper Battery
Last Post: Abaddon
29-09-2023 09:38 AM
