Threads: 10
Thanks Received: 11 in 6 posts
Thanks Given: 10
4
Hello, neither the Haynes comic nor the owners handbook list a location for a fuel pump fuse or relay. I assume there is one so could anybody direct me to it?
2015 Berlingo Enterprise 1.6 HDi
Threads: 75
Thanks Given: 223
164
13-07-2022, 09:08 PM
(This post was last modified: 13-07-2022, 09:12 PM by Sol.)
Threads: 10
Thanks Given: 10
4
Thank you very much. I saw that and assumed it was the high pressure pump that sends fuel directly to the injectors through steel pipes. Is that the case?
I am trying to find the fuse for the pump that sends fuel from the fuel tank to the fuel filter. Are they one and the same?
Threads: 75
Thanks Given: 223
164
14-07-2022, 01:27 PM
(This post was last modified: 14-07-2022, 02:03 PM by Sol.)
There is a lift pump combined with the tank gauge assembly, I found "Additional Fuel Pump" listed as BSI fuse F4 / 10A but it also operates the Diagnostic socket, Headlight adjustment, and a few rare optional (exotic) things like traction control switch & dimming rearview mirror so if the other items mentioned still work, then it is not that fuse.
See below: (7th fuse down, on RHS)
Threads: 10
Thanks Given: 10
4
I will check that out in the morning. Thank you.
