Courtesy light control fault
Hi all,
I was recently checking Diagbox to see if everything is ok and got a weird fault recorded. It is BSI A4A1, "Front/rear courtesy light lighting control fault. Short circuit to positive local" (Permanent local).
The car is a Pug Partner (M59; 2007, 1.6HDi; 92bhp). The fault seems pretty obvious, but everything works alright with the lights, they switch on/off, etc., without a problem.
I thought there was a problem with a lamp that was behaving weirdly and replaced all of them and the fault is still there. I cannot also erase that fault. Not too sure where this lighting control module might be located, might have to check servicebox to see where the lamp control goes to.
I know tracing electrical faults is rather difficult, but if you have an idea I would really appreciate it.
There is a permanent live for manual courtesy lights "on" along with the variable one for "theatre dimming", a trigger from the BSI for the door switch plus a ground, all wires go to the BSI1.
My guess is the switch contacts for off/on/auto with doors is maybe corroded or damaged and the BSI can see the plain 12V is getting to the theatre output wire? A short between pins 2 & 3 for example on module 3010. Also could be the same issue but in a rear light, is your roof antenna leaking maybe?
Interior Lights:
.pdf   M59 Lighting 1.pdf (Size: 621.24 KB / Downloads: 24)
.pdf   M59 Lighting 2.pdf (Size: 621.24 KB / Downloads: 17)
.pdf   M59 Lighting 3.pdf (Size: 621.24 KB / Downloads: 11)
  • saskak
(14-07-2022, 12:29 PM)Zion Wrote:  There is a permanent live for manual courtesy lights "on" along with the variable one for "theatre dimming", a trigger from the BSI for the door switch plus a ground, all wires go to the BSI1.
Interior Lights:
Sorry Zion,
I seem to have missed your reply. Many thanks indeed. The roof antenna seems to be alright and not leaking (as far as I can see), but I will probably have to inspect all the switches to see if they are all alright.
Many thanks again.
Interior Lights:
Yeah, there is continuity between pins 2-3, good call. I have to have a look at 40V BA to see if it is there as well. Probably chafing somewhere and these cables go around the whole car. Pulling trim around to trace it is something I really like to avoid.
Forum activity
Yesterday 05:02 PM
Emissions fault.
11-05-2025 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
Start stop on van
Last Post: Rhino2k
09-05-2025 10:28 PM
09-05-2025 09:34 PM
Insurance Shocker !!!
Last Post: Keefus.
09-05-2025 01:45 PM
Part of Dipstick Stuck
Last Post: Nice4dad
09-05-2025 01:25 PM
BSI central locking again
Last Post: stuffe
09-05-2025 09:24 AM
» Replies: 23
steering column bearings
07-05-2025 07:53 PM
