Rear brake imbalance on Handbrake.
Hello all, I've a strange one.
This morning I took Dorris in for her MOT and on the brake test it showed the following imbalance
SB Axle 1 - 4%
SB Axle 2 - 3%
PB Axle 2 - 32%
How would the Handbrake have such a large imbalance but not the foot brake?
Possibly a part-seized handbrake cable (they can crack and let water in) or the adjuster end of each cable is not even - access after taking plastic trim from handbrake -  there is a pivoting attachment but only has limited balancing effect.
(16-07-2022, 01:00 PM)oilyrag Wrote:  Possibly a part-seized handbrake cable (they can crack and let water in) or the adjuster end of each cable is not even - access after taking plastic trim from handbrake -  there is a pivoting attachment but only has limited balancing effect.
I was thinking the cable but wasn't sure.
It hasn't caused a failure and the tester never said anything about it but it's just me being picky. I live on a steep hill so wouldn't mind it being a bit less imbalanced. Might just replace the full cable for peace of mind but I'll not loss any sleep over it just yet.
Thanks for your reply
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
