New Leisure user
Hello forum people. I joined up because I've just bought a 2008 1.6hdi multispace to use on camping trips. It doesn't seem too bad but I'm going to be servicing it and changing the timing belt before long as it's done 71k miles. Starting in August I'm planning to do some joinery in the back to make a slide out camp kitchen and organise the kit storage.
Hey William. Glad you got fixed up with a motor, knew you were on the lookout for a Berlingo from living down the road. You're in the right place for helpful advice
If you're doing the belt, get the water pump replaced at the same time as it seems to be the biggest killer of timing belts.
There are how-to's of several pull-out camping units here on the site
Matt
   previous
   2016 1.6 HDi 100 XTR Grey Met
   2010 1.6 HDi 105 XTR Gold Met
(20-07-2022, 03:41 PM)Zion Wrote:  If you're doing the belt, get the water pump replaced at the same time as it seems to be the biggest killer of timing belts.
Will do! Also Tensioner, idler and whatnot.
(20-07-2022, 08:54 PM)Matt Haigh Wrote:  There are how-to's of several pull-out camping units here on the site
I noticed there's a section on it and I shall be perusing it in detail. I'll be giving it a gradual mechanical once-over first though. The car seems great but nothing makes a bloke feel more of a chump than a timing belt snapping after he's spent a few weeks fooling about with carpentry when he ought to have been skinning his knuckles under the bonnet
Hello, Welcome to the forum
(17-07-2022, 02:37 PM)WilliamFromEngland Wrote:  Hello forum people. I joined up because I've just bought a 2008 1.6hdi multispace to use on camping trips. It doesn't seem too bad but I'm going to be servicing it and changing the timing belt before long as it's done 71k miles. Starting in August I'm planning to do some joinery in the back to make a slide out camp kitchen and organise the kit storage.
Hi William.  Look forward to following your progress.
First: M49 Forte (Petrol)  Heart
Then: B9 XTR (Diesel)  Smile
Now: K9 Plus with Style Pack (Petrol)  Big Grin
Coolant
Last Post: tomhick024
Yesterday 06:18 PM
SOLVED: P20F6 fault
Yesterday 08:28 AM
Leaking windscreen or aerial
15-04-2026 08:50 PM
