Sliding passenger door won't open from the inside
Hi,
I have a 2002 berlingo that my Sliding passenger door won't open from the inside.
Does anyone know what the problem might be with my Sliding passenger door, it won't open from the inside?
I would be most grateful for any suggestions, thanks
It's usually the linkage come adrift inside somewhere. The door trim has to come off to find it and clips always break when removing them.
(18-07-2022, 09:40 AM)ffrenchie Wrote:  It's usually the linkage come adrift inside somewhere. The door trim has to come off to find it and clips always break when removing them.
Thanks I will try that and see what happens.
Not just the child lock?
Geoff
[-] The following 1 user says Thank You to Guanock for this post:
  • ffrenchie
(19-07-2022, 12:40 AM)Guanock Wrote:  Not just the child lock?
Geoff
If it's the child lock it's an easy fix. Just in front of the outside handle on the lock face of the door is a slot which needs a quarter turn with the end of the ignition key. I thought he would have tried that  Confused
Geoff
I have tried anything yet as it's too hot, but I will try the child lock first. thanks
I have tried the child lock and it's the same after turning it both ways, and the button on the inside springs out. So I don't know what to try next.
If someone has any ideas I would be most grateful.Thanks
Coolant
Last Post: tomhick024
Yesterday 06:18 PM
SOLVED: P20F6 fault
Yesterday 08:28 AM
Leaking windscreen or aerial
15-04-2026 08:50 PM
