Threads: 6
Thanks Received: 1 in 1 posts
Thanks Given: 4
Hi,
Has anybody found any issues with the aircon pump when switched on and it makes the engine hesitate at low revs?
I know the pump adds more load to the engine when switched on but I'm wondering if the pump is starting to seize.
Any help appreciated.
Threads: 123
Thanks Given: 250
34
Welcome. AFAIK, the AC pump / compressor should make a click noise as the electric clutch engages and maybe a momentary hesitation in the revs as the engine takes the load but it should recover.
The following 1 user says Thank You to cancunia for this post:1 user says Thank You to cancunia for this post
• Imc500
Threads: 10
Thanks Received: 11 in 6 posts
Thanks Given: 10
4
When my ac compressor clutch engages there is a noticeable change in engine sound for a second while it winds up but no hesitation or stutter. Sounds like yours is putting an undue load on the engine.
2015 Berlingo Enterprise 1.6 HDi
