20-07-2022, 09:55 AM
Hello All,
New owner of a 2014 B9 Berlingo Van - (after driving one through work, I really liked it so looked for my own)
I am trying to retrofit Cruise Control only (No limiter) So I don't need the pedal and the stalk is the cruise only stalk (Part Number 96336889XT)
Dash LCD has the cruise symbol present, Brake switch and clutch switch present and working correctly.
However I get to the last bit of the process and the ECU says programming Failed!
Here's the process so far:
Installed the Stalk
Cut the Shroud to fit
Entered into BSI > Manual Configuration > Driving Assistance > Change "Presence and type of Cruise" to "Cruise Control"
Save Configuration - Result - "Configuration Performed"
Back up to then Enter the ECU
ECU > Configuration > Downloading > Change "Cruise Control" from "absent" to "present" > Save Configuration > Switch off Ignition 30s
When I turn the ignition back on after 30s it says "Programming Failed" and the cruise control still states "absent"
I am using an Autel Maxisys MS908S PRO - Which is a very powerful system, and has all the relevant menus available to do the retrofit.
However I am wondering if a copy of Diagbox would have success. I Don't necessarily want to purchase it only to have the same programming Failed error.
Does anyone have any tips on what to look out for or double check to get the programming to work.
I am in Wakefield - if any locals have Diagbox and wouldn't mind trying for me ?
Cheers in advance
Charlie
Installed the Stalk
Cheers in advance
Charlie
