20-07-2022, 02:34 PM
hello I just joined this forum today as we have a 2018 Berlingo diesel (mobility adapted) and since May we have not been able to use the car much as the eloys tank developed a leak (and in the mobility conversion the tank is fitted inside the car under the rear passenger underfloor storage box so the fumes are not good). It leaks where the pipe goes into the tank and so needs new tank and pipe (already got the pipe). The local Citroen dealer has had a new tank on order since May from Citroen but still no idea when it will arrive. I've looked at all the usual EU car part suppliers and none seem available nor on any used site. Does anyone know where we can get a new/used tank part no 98016296080 (this is the part number the dealer is quoting).
Any ideas welcome or indeed if the plastic pipe on the pump can be repaired somehow and then it can be refilled with this expensive fluid.
