[Engine] eolys system
hello I just joined this forum yesterday and maybe posted in wrong place (introductions, trying to find my way around how this forum works) as we have a 2018 Berlingo diesel (mobility adapted) and since May we have not been able to use the car much as the eloys tank developed a leak (and in the mobility conversion the tank is fitted inside the car under the rear passenger underfloor storage box so the fumes are not good).  It leaks where the pipe goes into the tank and so needs new tank and pipe (already got the pipe). The local Citroen dealer has had a new tank on order since May from Citroen but still no idea when it will arrive. I've looked at all the usual EU car part suppliers and none seem available nor on any used site. Does anyone know where we can get a new/used tank part no 98016296080 (this is the part number the dealer is quoting).
Any ideas welcome or indeed if the plastic pipe on the pump can be repaired somehow and then it can be refilled with this expensive fluid.
Thanks [Image: smile.png]
ps someone asked about Adblue and Eolys - this model has both systems, talk about belt and braces!!
The reason for both, is the change from Euro 5 to Euro 6 which had stricter levels of NOx emissions. Adblue brings the NOx levels down to the required limit while Eolys helps to burn off soot in the DPF. It also reduces NOx but not by enough to be approved for Euro 6 so I think they retro fitted vehicles already in production or stock with Adblue tanks, so they could still be sold in the EU. They presumably already had the Eolys system fitted from before.
So how to tell if my 2018 1.5HDI has Eolys fitted?
What does it look like, where is it fitted etc?
Geoff
If you have an Adblue cap next to the fuel cap, then check under the vehicle and just ahead of the drivers side rear wheel, there will be a large black plastic box bolted to the underside. That contains the Eolys system, pouch and pump. It's not a tank but it looks like one.
From what I've seen the 2016 was the most likely to have both systems. Depends on the build date (check the RPO number in my database - how to section) but some 2018 reg vans seem to still have both. I can't see a vehicle sitting two years between build and registration. Seems odd some late B9s have the dual setup and some don't.
Thanks Zion. I have not noticed the plastic box, but will have a better look tomorrow. Fingers crossed as it appears to be yet another complication.
Geoff
Hi Zion
I have looked in the area described, in front of the driver's side rear wheel and no sign of a black box. The only significant component in that area is a round black plastic housing. It has a drain plug and a female hexagon aperture. I am pretty sure it is the main fuel filter housing.
Anyway good to know it does not have Eolys.
Thanks for your help
Geoff
No problems, it's pretty visible when you have it as the cover is an obvious big black box so it stands out.
(21-07-2022, 08:52 AM)berlingogreen Wrote:  hello I just joined this forum yesterday and maybe posted in wrong place (introductions, trying to find my way around how this forum works) as we have a 2018 Berlingo diesel (mobility adapted) and since May we have not been able to use the car much as the eloys tank developed a leak (and in the mobility conversion the tank is fitted inside the car under the rear passenger underfloor storage box so the fumes are not good).  It leaks where the pipe goes into the tank and so needs new tank and pipe (already got the pipe). The local Citroen dealer has had a new tank on order since May from Citroen but still no idea when it will arrive. I've looked at all the usual EU car part suppliers and none seem available nor on any used site. Does anyone know where we can get a new/used tank part no 98016296080 (this is the part number the dealer is quoting).
hello I did not get any useful reply to this - does anybody have an eolys tank for this 2018 model as we are stuck??
Post in the parts wanted section, or check eBay for "breaking Berlingo" and send the seller a message. This tank will be a bit rare, not sure how easily you will find one. Must be a wav getting dismantled somewhere.
(04-08-2022, 09:48 AM)Zion Wrote:  Post in the parts wanted section, or check eBay for "breaking Berlingo" and send the seller a message. This tank will be a bit rare, not sure how easily you will find one. Must be a wav getting dismantled somewhere.
yes I tried breakers. will try parts wanted section, thanks.
Today 06:32 AM
Clocks dropping out
Last Post: Micklew
Yesterday 09:29 PM
air con
Last Post: magoo1
Yesterday 04:56 PM
triangle light
Last Post: Buki
Yesterday 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
