Using parts from 2005 1.6 diesel into 2013 model, 1.6 diesel
Hi I own 2005 and 2013  berlingo, both 1.6 diesels. I wonder ig engine parts are compatible?
Regards
D
Probably not, the 2005 will be a 16Valve & the later engines are 8Valve, not 100% sure when they switched to 8V but I think all B9 models will have the later engine.
Also the 2013 probably has the newer style fake Doseur and a different angle of exit on the turbo outlet pipe. They did away with the Air Doser (or Doseur) in 2012 so the control system is different.
Yesterday 12:17 PM
Last Post: wbchevron
Yesterday 09:32 AM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
