25-07-2022, 10:15 AM
Do fault codes need to be manually cleared after the problem has been fixed? Specifically in this case, "anti-pollution faulty".
Had my exhaust replaced by my garage, but they had to do it quickly as I needed the car, and so they weren't able to fix a slight blow from the downpipe/manifold interface (they needed to wait for the cat to cool down, and I didn't have time to wait). They also warned me they had to retap the second lambda sensor, and it might be ok but might need replacing. So there's two possible causes of the fault. I took the downpipe off, cleaned up the mating faces and refitted it tightly and I think I've fixed the blow.
The fault appeared the second time I ran the car after the exhaust was replaced (not on the way back from the garage, but a quarter of a mile into a week long 700 mile trip.
). After that, it came up immediately every time I started up, so I guess it's latched and needs clearing.
I can borrow a diag box off a friend, assuming there's no other way of clearing it?
). After that, it came up immediately every time I started up, so I guess it's latched and needs clearing.I can borrow a diag box off a friend, assuming there's no other way of clearing it?
