Threads: 4
26-07-2022, 12:43 PM
Hello all Berlingo people. Is there any way I can make my 2wd Berlingo look more like a 4x4 Berlingo? I mean make it higher in the front so I can go a bit off-road. Would it be enough to just change the springs?
Threads: 54
Thanks Received: 81 in 75 posts
Thanks Given: 147
7
There was a 4x4 Berlingo, google some pictures, that may be the look you are after
Matt
previous
2016 1.6 HDi 100 XTR Grey Met
2010 1.6 HDi 105 XTR Gold Met
Threads: 39
Thanks Given: 1
4
One of the M59 Peugeot Partner versions had raised suspension
Peter
Threads: 5
Thanks Given: 4
21
Traction is pretty poor no matter how much the suspension is raised.
I have trouble getting up my driveway in wet weather so mud etc. is going to be challenging with 2WD!
Threads: 29
Thanks Given: 67
20
27-07-2022, 08:22 AM
(This post was last modified: 27-07-2022, 08:25 AM by ffrenchie.)
There was a version available with limited slip differential to give it a bit better rough ground performance. Peugeot Partner Combi had a few off road pretensions with grills on the lights and higher ride.
Threads: 4
Thansk for the fast answers. Im not really looking for traction. Im only looking for looks. I want my 2wd to be as high as the 4x4 in the front.
Threads: 48
Thanks Given: 4
20
For the 1.4i/MA5 users there's a 'LSD'
out there that uses a slightly different tech that gives a much moother operation. It has been used a lot in rallying models with that engine and gearbox. It's actually manufactured in England, but I think the price is over £500, and you need to completely dismantle the gearbox to fit it.
If you just want the looks, I'd suggest checking around on breakers yards for a scrapped 4x4 and get the parts off of that. Then you'd know that the parts fits...
Threads: 13
Thanks Received: 32 in 24 posts
Thanks Given: 8
Peugeot Partner Escapade has 30mm longer shocks and different springs to a Berlingo. I have one and rebuilt it's front end when I bought it - the part numbers are all different between the two models.
The Escapade also have a substantial steel sump/skid plate and the light guards as mentioned above.
2004 Peugeot Escapade 2.0HDI. 115k miles
2004 Volvo V70 2.4 208k miles
2011 Volvo XC90 215k miles
2005 Porsche Cayenne 170k miles
Threads: 17
Thanks Received: 13 in 10 posts
Thanks Given: 16
4
Pretty interesting that the escapade has more than just skin-deep differences.
