start stop system
The engine will now never go into standby when I brake, and has been in this state for many weeks, even after long trips, which I assumed would get the battery fully charged. Is this a problem I can just ignore, and assume I will get a warning light if the battery is dangerously low? I get the green flashing curly arrow on braking, but have assumed this indicates a lack of full charge/low temp/engine not running for long enough, but it will react in the same way any conditions now.
Hi
I have a 2016 B9 & have had a couple of new batteries.
From new & each time they have been replaced, the stop start system works for approx 3 months.
I assume the stop\start only works when the battery is in tip top condition
(30-07-2022, 08:27 PM)Roy Atherton Wrote:  The engine will now never go into standby when I brake, and has been in this state for many weeks, even after long trips, which I assumed would get the battery fully charged. Is this a problem I can just ignore, and assume I will get a warning light if the battery is dangerously low? I get the green flashing curly arrow on braking, but have assumed this indicates a lack of full charge/low temp/engine not running for long enough, but it will react in the same way any conditions now.
I have a K9 1.2 petrol van registered 2020 which I purchased with only 10 miles on the clock. The Stop/Start has never operated (now 12000 miles). Just get the flashing symbol which I think indicates i'ts not available due to battery discharge rate.
I've also found that with the engine off and using auxiliaries like hazard flashers these go off after a few minutes due I believe to the "Eco Mode' activating to protect the battery.
At the moment I'm not concerned about this mainly because I don't like the Stop/Start facility anyway and my battery seems to check out ok so I think it is just Eco mode being quite sensitive.
Might be worth switching the air conditioning off and anything else that's loading the battery and see if there is a difference.
[-] The following 1 user says Thank You to Joe1953 for this post:
  • Roy Atherton
I copied into a post a few months ago what the handbook says about the stop/start. It does seem to have a window when it works and other times, not.
Regarding the Stop/Start - the handbook says the following -
"Main conditions for operation
– The driver’s door must be closed.
– The sliding side door must be closed.
– The driver's seat belt must be fastened.
– The state of charge of the battery must be
sufficient.
– The temperature of the engine must be within
its nominal operating range.
– The outside temperature must be between
0°C and 35°C.
Special cases:
The engine will not go into standby if all of the
conditions for operation are not met and in the
following cases.
– Steep slope (ascending or descending).
– Vehicle has not exceeded 6 mph (10 km/h)
since the last engine start (with the key or the
“START/STOP” button).
– The electric parking brake is applied or being
applied.
– Needed to maintain a comfortable temperature
in the passenger compartment.
– Demisting active.
In these cases, this indicator lamp flashes
for a few seconds, then goes off.
After the engine has restarted, STOP
mode is not available until the vehicle
has reached a speed of 5 mph (8 km/h).
During parking manoeuvres, STOP mode
is not available for a few seconds after
coming out of reverse gear or turning the
steering wheel."
Now a 2019 K9 1.2 petrol.
[-] The following 1 user says Thank You to Mark604 for this post:
  • Roy Atherton
(31-07-2022, 03:18 AM)Aussie Berlingo mk3 Wrote:  Hi
But does your battery keep going though not in tip top condition after 3 months? ie, the problem is not an indication of continuous deterioration of the battery?  thanks for your input, and I think that I will just ignore what seems a minor problem, in the hope that the battery will not just die on me.
If you are running with the aircon on in the current hot weather the stop/start does not work - as per the handbook bit above – "Needed to maintain a comfortable temperature in the passenger compartment".
2020  1.5 Blue HDi 130 Berlingo XTR
2009  1.5 Diesel Peugeot Partner
2007  1.5 Diesel Berlingo Desire
2003  Petrol Berlingo
Yes, the battery will keep on going. My berlingo has done 210,000km, it's just had its 3rd battery installed
Where is 2011 Berlingo parking sensor ECU?
Last Post: Gene1
Yesterday 09:28 PM
BSI
Last Post: jemselectrical
Yesterday 08:53 PM
» Replies: 16
M59 BSI Technical Document (Citroen Training)
Last Post: Zion
Yesterday 07:07 PM
Cup Holder Fitting
Last Post: Gadgetman
Yesterday 05:54 PM
Electric probs - where to start
Last Post: BigVtwin996
Yesterday 05:26 PM
Stuck glow plug tip - I've tried it all - It won...
Last Post: DeSender
Yesterday 05:15 PM
Berlingo/partner 2019 Gearbox real or fake?
Last Post: Zion
Yesterday 04:59 PM
Removing footwell carpet - problem
Yesterday 09:05 AM
Rear back door air gap??
Last Post: Gene1
Yesterday 08:24 AM
Problème ABS
Last Post: Zion
Yesterday 07:36 AM
