  • 28 Vote(s) - 2.86 Average
[Engine] Diesel Particulate Filter
Hi, newbie, first post: I have a 2003 2.0 HDI. I am looking for a newer one but am concerned about dpf problems. I am considering a 2007 1.6HDI, which apparently has dpf in the catalytic converter. Is this the type of dpf that might cause me problems with short trips? If it's just a warning light coming on that means ' you need a blast down the bypass for 20 mins.',that's not a problem. Or is it not as simple as that?
Wouldn't worry about it. I've a mk 3 with dpf and drive 80% city. Never a problem. Twice a month 5 minutes at 90-120 kmph and the light has never gone on. There is an additive dispenser that adds something to help keep it clean. The dispenser needs to be refilled as normal maintenance every 80K or 100K km. Forget which. I also use a good diesel (Shell V-Power) and change oil regularly with Total Quartz Ineo ecs 5W-30 as recommended by PSA for motors with dpf.
(07-02-2012, 06:54 PM)3rensho Wrote:  Wouldn't worry about it. I've a mk 3 with dpf and drive 80% city. Never a problem. Twice a month 5 minutes at 90-120 kmph and the light has never gone on. There is an additive dispenser that adds something to help keep it clean. The dispenser needs to be refilled as normal maintenance every 80K or 100K km. Forget which. I also use a good diesel (Shell V-Power) and change oil regularly with Total Quartz Ineo ecs 5W-30 as recommended by PSA for motors with dpf.
Is there an additive dispenser on the M59?
If so, where is it?
what is a dfp
(07-02-2012, 06:57 PM)berlingo power Wrote:  what is a dfp
The clue is in the title to the topic.... Diesel Particulate Filter
Look just above where you have typed dfp.
[-] The following 1 user says Thank You to j90xxx for this post:
  • andy-womble
(07-02-2012, 07:00 PM)j90xxx Wrote:  Look just above where you have typed dfp.
pfd ????
lol stupid me
Check this link....
http://en.wikipedia.org/wiki/Diesel_Particulate_Filter
Or FAP.
Filtre a particules.
That's French. (Surprisingly...)
  • andy-womble
can these just be removed, i like the black smoke out the back.
Last Post: deejay_xb
Today 10:06 AM
» Replies: 32
XL tyres
Today 09:26 AM
Unusual Braking Problem
Today 07:57 AM
Outer cv boot replacement
Yesterday 10:13 PM
Yesterday 10:02 PM
Diagnostic Plug
Yesterday 09:55 PM
Yesterday 09:52 PM
Rumbling Noise 55-65mph
Yesterday 09:47 PM
Last Post: Beaumotor
21-03-2025 04:38 PM
engine light
21-03-2025 09:25 AM
