Threads: 68
Thanks Received: 1,171 in 1,037 posts
Thanks Given: 194
147
Is it random flickering or a steady pulsing? Does it do this constantly or only when moving? Does it only do it when the engine is running, or even with just the ignition on?
Threads: 121
Thanks Received: 620 in 578 posts
Thanks Given: 247
34
02-08-2022, 06:53 AM
(This post was last modified: 02-08-2022, 06:53 AM by cancunia.)
They are easy enough to remove (search on here and elsewhere for MFD), you could just disconnect & re-connect to see if that helps. If the MFD is faulty, they are also quite common but just need to be careful that you get one with the right connector as it might be different on the M49. Take a note / picture of the part number & a picture of the connector while it's out and post here?
Threads: 27
Thanks Received: 372 in 326 posts
Thanks Given: 63
19
Ours in the M59 does it but only when it's cold and damp.
