Thanks Given: 1
Can anyone help please daft question but how can i find out what type off rear wheel bearing i need with out taking out the old one reason i am asking this is
because i have rear break shoes on the back and the rear wheel bearing i bought got rear teeth on back and some are not do i have the right one ? my belingo is
2004 if that helps
Threads: 8
Thanks Received: 507 in 455 posts
Thanks Given: 305
37
The hub bearing with teeth (Reluctor Ring) is for vehicles with ABS which you can have with drum brakes.
Does you car have ABS ? . . . You will have an ABS warning lamp on the dash that lights up when you turn on the ignition, or look for the ABS pump, it's situated in the engine compartment behind the battery close to the bulk head.
(Search Google for Berlingo ABS pump to see what they look like if you don't know)
Citroen part numbers of the rear hub bearing are...
No ABS - 3748 43
With ABS - 3748 44
I think the ABS rear hub version will more than likely fit cars with no ABS as I would guess the only difference between the two will be the reluctor ring (Teeth)
• daz13
