Threads: 73
Thanks Received: 46 in 35 posts
My 2009 berlingo b9. Do anyone have problem with knocking driving on humps?
I have change swaybars, swaybar rubber, tierod, lower ball joint, complete suspension. And still got the knocking.
Threads: 39
Thanks Given: 1
4
Anti roll bar where it runs across the front subframe?
Peter
Threads: 5
Thanks Given: 4
21
When you say complete suspension, did that include the upper strut mounts/bearings?
Threads: 75
Thanks Given: 223
164
05-08-2022, 07:07 PM
(This post was last modified: 05-08-2022, 07:09 PM by Sol.)
Strut top mounts / bushes / bearings
Edit...just saw oilyrags post above. He already said what I was thinking.
Threads: 39
Thanks Given: 1
4
I know mine was on an M59 but having done strut tops, drop links etc and still having the knocking I discovered that the anti roll bar bushes (the nes that hold the bar to the subframe) were worn and the bar was touching the subframe in certain circumstances and it came across as a knock. I replaced those bushes and it fixed it but be warned it is a PITA of a job as you have to lower the subframe a bit to gain access
Peter
Threads: 75
Thanks Given: 223
164
Good shout Pete, also worth checking.
Threads: 2
Thanks Received: 1 in 1 posts
Thanks Given: 3
Just something to check when your doing the top mounts, check for movement in the shock absorber by holding the top of the piston and the strut and just try and rock it back and forth. This can cause a knocking and/or create a “click” feel through the Car when moving off in traffic
