Noise Automatic Gearbox EAT8
Hello,
I have a '22 Berlingo 1.5 HDI EAT8 gearbox, and I can hear some rattle noise on EAT8 gearbox while acceleration on 7TH gear only.
If I reduce to 6TH or engage 8TH it will not make any strange noise.
Is this a normal thing on 7TH gear or I have a damaged gearbox...?
Thank you.
under acceleration my 7th gear is noticeably louder, but more in a throaty way
(10-08-2022, 03:45 PM)Tree Wrote:  under acceleration my 7th gear is noticeably louder, but more in a throaty way
And if you reduce to 6TH gear or change to 8TH gear, it's quieter, right?
indeed it is
indeed it is
Really strange thing. I thought the 7TH was damaged, if your is same, so it should be normal thing.
Hi there.
My berlingo has been doing this noise in 7th (and in some circumstances in 5th) since new. I don't remember it being so loud, o maybe now I'm more aware since I'm paying more attention. The noise in 7th sounds more like air intake or something different to gearbox itself since driving without throttle doesn't make any noise. Also, when the gearbox is cold and gears are still not engaging fully, the noise is not present. It is when the gears fully engage and only when light to medium throttle.
Did any of you get to know anything else relate to this? Thank you.
Hello,
I have still not reported it, but as the car is on warranty, I will report it, it seems to make on odd gears (5, 7).
The gears are not fully engaging? Are you sure? How many miles have your car? Have you changed the gearbox oil?
This AISIN Gearboxes seems to be good, however it's better to report it, as it is not normal.
(13-12-2022, 09:34 PM)cgentil Wrote:  The gears are not fully engaging? Are you sure? How many miles have your car? Have you changed the gearbox oil?
Mine was bought in late january 2021. That winter and this 2022 winter, when it was freezing overnight (mine sleep in street), that always have been the behaviour from day one. Maybe I did't explain myself properly (i'm spanish sorry for bad english). In this other topic they talk about the cold slipping for the eay8 https://www.peugeotforums.com/threads/30...ld.331256/. Supposed a normal behaviour to protect the gearbox when cold and to warm up faster. In this other topic https://www.clubpeugeot.es/topic/38237-f...ent=353207 they talk about it as well. I link to a comment where there is a video showing the revs not matching the speed.
I have not changed the gearbox oil. It currently has 25000 kms. According to official maintenance, gearbox it is not serviced lifetime. But according to aising it should be done at 60000kms, which i will do in a specialied gearbox workshop
(13-12-2022, 09:34 PM)cgentil Wrote:  Hello,
Have you reported it? Mine can get a bit noisy on the fifth gear when between 1800-2000 rpm, it seems more noticeable than higher gears on bigger rpm
Hello,
Will report on next service.
Last Post: BigVtwin996
Today 12:10 PM
Eolys replacement tank
Last Post: jw4821
Today 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
