Threads: 5
Thanks Received: 1 in 1 posts
Thanks Given: 4
10-08-2022, 05:19 PM
(This post was last modified: 10-08-2022, 05:25 PM by robjwood.)
When I switch the air-con on, the vents on the passenger side both blow air but it's not cold air-conditioned air.
On the drivers' side, the air is definitely a little cooler but not as cold as it should be.
When you click the air-con switch, you can hear a little click and sound a bit like a balloon being deflated. If the air-con just needed re-gassing would it behave like this?
Has anyone else experienced the same thing before?
My car: 2012 Citroen Berlingo Multispace XTR - 1.6 HDI 7J9HP
Threads: 5
Thanks Received: 51 in 39 posts
Thanks Given: 19
7
This is a classic symptom of a lack of gas in the system. Evaporation ends at half of the evaporator so the other side is not cooled at all.
Fill up with gas and check for leaks.
Threads: 5
Thanks Given: 4
I'm hoping that's all it is. Thanks for the response.
Threads: 5
Thanks Given: 19
7
All B9's use the old r134a refrigerant until at least 2016 and most likely until the end of production (2018).
Threads: 5
Thanks Given: 4
Thanks for the replies
Threads: 29
Thanks Given: 67
20
Look under the bonnet. If the gas is too low the compressor clutch will not kick in. It's a safeguard to preserve the compressor from running dry.
Threads: 5
Thanks Given: 19
7
13-08-2022, 09:27 PM
(This post was last modified: 13-08-2022, 11:51 PM by Buki.)
The B9 fitted with variable displacement compressor, it does not have a magnetic clutch. The compressor rotates all the time along with the belt, the air conditioner is turned on by a control valve inside the compressor.
The following 1 user says Thank You to Buki for this post:1 user says Thank You to Buki for this post
• ffrenchie
Threads: 29
Thanks Given: 67
20
Thanks Buki, our older M59 still has the clutch and can hear it kick in.
