Blower fan not working
Without any warning the blower fan stopped working on all 4 speed settings.
An internet video showed that if it was not the fuse it could be the relay, I have checked both an they are OK, in fact I dismantled the relay and it works fine despite some discolouration around some of the terminals. That leads me to think that it could be the fan motor or the rotary switch, any ideas?
Video link Peugeot Partner Blower Motor Not Working - Problem Solved - YouTube
I now wonder if it is the resister: Peugeot Partner Citroen Belingo Heater Resister Replacement - YouTube
Dave
Can you get 12v across the fan to test? If that’s ok only leaves the switch.
(12-08-2022, 05:31 PM)OMG Wrote:  Can you get 12v across the fan to test? If that’s ok only leaves the switch.
Having just watched the "resister" video, is the fan motor above the accelerator pedal?
Yes it is. Here's my thread showing the process of removal and testing, when mine failed.
Normally it's the resistor, which lives above the accelerator pedal next to the fan itself. I pulled both:
https://www.berlingoforum.com/thread-201...#pid127842
Yesterday 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
