Berlingo 1.4 Immobiliser fault?
Looking at  by-passing the immo?
TUJP3 engine dies, Citroen Berlingo?
Van dies coming up the hill into the farm and i think it is low on fuel, not picking up fuel because of the slope.
I put more fuel in it and can hear the pump but it won't start.
Next day we get it back to level ground on a trailer and i notice we are getting fuel to manifold on the cranking .
I clean the crank position sensor of all the grime and no luck.
The coil pack was replaced with a new one 2 years back.
No poor running , fully expected fuel pump failure and to be taking the petrol tank out on the roadside!
*next step tomorrow see if any fault show on the diagnostic tool.
*Will spark /injection faults show on the diagnostic tool?
Any ideas?
Next day,
Fault code P1612/P40
Or
P0135/P40
Indicates upper exhaust sensor?
Tried another coil pack and TDC unit nothing.
Is there a fuse some where?
Can't find my Noid Light so can't check for pulse.
The van was loaded on to a trailer taken to the farm , 300klms from any garage that actually knows anything about French cars.
Is there any way of by-passing the Immo so i can start it?
I have good fuel pressure to the injection rail.
G'Day!
What engine does it have?
You mention coil packs (petrol) & injection rail (diesel).
Fella says its a 1.4 TUJP3 and I guess that the fuel pressure found is at the bleed nipple on the end of the fuel supply (rail).
(15-08-2022, 09:02 AM)oilyrag Wrote:  Fella says its a 1.4 TUJP3 and I guess that the fuel pressure found is at the bleed nipple on the end of the fuel supply (rail).
Saw the TUJP3 but not the 1.4, must confess that I didn't know TUJP3 is petrol.
So, petrol in that case!
Immo off?
Seems odd if it is the immob. as it happened with the engine running.
Have you checked the auto-cut off thing that actuates if you hit something - left side of engine bay - mine's a large red button.
Last Post: TGD
Yesterday 09:50 PM
Yesterday 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
