Removing rear seats
Which model is the one you can legally remove the rear seats, I need the whole space like a van, but I still want the windows all around.
You can easily remove the seats on the Berlingo Multispace, the van came first so the car is easy to strip back to near van proportions.
It's a van derived car, not a car derived van! Hope this helps. Just take them out, it's never illegal to remove seats. Can be illegal if you add them to a van and it's not done properly. But not the other way round.
______________________
Not a Citroen!
2017 B9 1.6 BlueHDi Van
2012 B9 1.6 HDi Van
2008 M59 1.6 HDi Van
2003 M59 1.9D Van
[-] The following 1 user says Thank You to Sol for this post:
  • BOFF
(21-08-2022, 08:22 PM)BOFF Wrote:  Which model is the one you can legally remove the rear seats, I need the whole space like a van, but I still want the windows all around.
It's matter of opinion about 'legally' removing the rear seats from the M49 & M59 as they need to be unscrewed from the floor so some might consider that a modification and it might be best to inform the insurers. On the later B9 (&K9?), the seats are removable via a catch & AFAIK, this is described in the owner's handbook so there should be no problem. At MOT time if the seats are put back in, there's no chance of advisory comments about not being able to check the rear seat belt.
[-] The following 2 users say Thank You to cancunia for this post:
  • BOFF, Sol
It's also possible that if the item isn't fitted, it can't be tested and will just result in a note, if at all. Like the spare wheel, if it's there it must be good. If not, they don't mention it.
Not a Citroen!
2012 B9 1.6 HDi Van
2003 M59 1.9D Van
Today 12:08 PM
Last Post: kulat
Yesterday 09:59 PM
31-08-2026 08:50 PM
How to fit grease nipple on rear axle berlingo
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
Repair recommendations while servicing DPF
24-08-2026 07:58 PM
Rear disks and increasing ride height
23-08-2026 06:25 AM
1.6hdi 2007 exhaust fumes smell
Last Post: stu76
18-08-2026 07:16 PM
Random starting/running fault.
Last Post: Kieron G
16-08-2026 08:18 AM
