  • 20 Vote(s) - 2.55 Average
HEATER SWITCH NOT WORKING
Well folks.
bought a Berlingo to run me to work and back. iv found my heater switch doesn't work and cant seem to find power going to the plug. any ideas on how to fix or were to start to check ? its a 2001 1.9D
thanks
This might be a good place to start:
heater thread
on my mk11 the heater motor control failed mine has air con if yours dont it may be the resistor pack.
got sorted... a loose wire !!
took for a full service, timing belt, all the filters, oil, anti freeze and changed the brake disks and pads (£200 was the total bill) looked at the heater and when moving wires it started, i now have heat..
(13-02-2012, 07:18 PM)devil Wrote:  got sorted... a loose wire !!
Hee Hee, the old Citroen/Pugeot Wiggle-Wiggle test works again.... why are the electrics so shite ????.....
By the way, sounds like a good price on the service for all that lot, Nice one...
mate is a mechanic :woop:
Yesterday 03:29 PM
Last Post: Triggermann
Yesterday 01:47 PM
15-07-2026 12:17 PM
Last Post: wbchevron
15-07-2026 09:32 AM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
