Threads: 2
Thanks Received: 1 in 1 posts
I seen this subject pop up a few times, has anybody heard if there was a fix for this ? I read somewhere it was to do with the rear axle. Mines had 4 wheel alignment twice and callipers all checked. As I say I’ve seen plenty of posts regarding it but no cures..
Threads: 0
I have a 2016 berlingo, I have inproved this by adjusting the rear axle, Loosen the attach bolts of the axle to the body and push the left side fully back and the right side push fully forward, this changes the thrust angle. I only did this a few months ago, I have to see how tyre wear is affected.
There is still a pull to the left but huge improvement from where it was.
Threads: 8
Thanks Given: 8
I saw a post elsewhere that said it is indeed a rear axel alignment issue and that very, very few dealers have the necessary alignment jig to actually set this up correctly. I suppose even if they had the kit it would cost a fortune to get it done.
