K9 roof bars
Hello everyone,
I am looking for roof bars for our K9. Our car has roof racks and it looks like no used bars I tried could fit these as the racks are too thick/wide.
Would be grateful for advice on roof bar mounts that would fit the Thule steel square roof bars as we have bicycle racks that can be used only with those. Thanks.
We searched liw and high for bars for our XTR buy kept turning up blanks. I contacted Thule to see when /if they intended to produce a kit as like you I have a variety of thule bars and kits. But they said thy had no proposals to produce a kit to fit the huge longitudinal bars.
I contemplated removing the fitted longitudinal bars thinking you could most likely then use the integral fittings with bars meant for the commercial vehicles. You could then also have 3 bars for a more secure and stronger load bearing.
But in the end I just stumped up the huge amount for the Citroën parts.
These naturally fit well and easily although the plastic understrap doesn't entirely fill me with confidence. Hopefully it's mot plastic but kevlar or something!
The Citroen roof bars for the K9 roof rails are great, look like they are actually made by Thule. Easy to get on and off.
Matt
   previous
   2016 1.6 HDi 100 XTR Grey Met
   2010 1.6 HDi 105 XTR Gold Met
Link?
ex: 2003 1.4i cargo
Maybe these? https://citroen-shop.eu/gb/exterior-acce...go-k9.html
Oh, thanks. In my mind these were flush bars which probably still don't exist.
ex: 2003 1.4i cargo
(29-08-2022, 09:47 AM)Superelastik Wrote:  We searched liw and high for bars for our XTR buy kept turning up blanks. I contacted Thule to see when /if they  intended to produce a kit as like you I have a variety of thule bars and kits. But they said thy had no proposals to produce a kit to fit the huge longitudinal bars.
The "plastic understrap" has a stainless steel core
Matt
   previous
I had Thule wing bars and fixings on my B9 and just transferred them over to my K9 and they were fine. It's odd because I just checked on the Thule website and it says they are not compatible... and yet they're currently on my car!
2022-  Citroen Berlingo Puretech Flair XTR M Eat8 1.2 automatic petrol - Soft sand, with modutop
2011-2022 - Citroen Berlingo Multispace XTR 1.6 HDi manual diesel - Iron grey, with modutop
(29-08-2022, 10:42 PM)Matt Haigh Wrote:  The Citroen roof bars for the K9 roof rails are great, look like they are actually made by Thule. Easy to get on and off.
I agree - looking at the link shared below, they look exactly like the Thule ones I had, which I moved across from my B9 to my K9.
My Berlingo Multispaces
Yesterday 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
