30-08-2022, 01:44 PM
Hello gentlemen!
Long time lurker, but no poster until now out of pure desperation.
Picked up the old steed (M59 2.0 HDI Van) a couple of years ago. It was cheap as back doors had been broken into, steering rack unions were cross threaded and were leaking quicker than you could top up the reservoir, rad was split and once replacing rad I'd found out headgasket was blown as well...
Anyway I sorted the headgasket, did a timing belt same time, removed the power steering pump and lines, took rack off and packed it full of grease and removed the hydraulic ram, replaced rad, rad fans, fitted an intercooler, some hard pipes and got an unlocked remapped ECU (SID 801A) from Steve @ HDI Tuning. So far so good, van would start and go quite well, no further issues with water etc. however ever since I've got it I've had a recurring "hot" starting issue.
First start of the day it's always good, within 2 turns of the starter motor I'm met with the familiar calming tractor noise. I've driven it up and down the country for work and it has not once cut out or missed a beat, juddered or otherwise behaved incorrectly. Once started however, the moment you shut it off - whether it's 35 seconds after just moving it up the drive or after a 4 hour drive no amount of cranking seems to get it started right away. It will sometimes start after 2 turns and sometimes won't after a minute on the starter. Having had Lexia on it I can report the following:
- Cranking pressure going up to 400 bar then regulator kicking in and sending it back to 290-300 so that's good. (Rebuilt injectors, rebuilt pump)
- Cranking RPM of 250-290 RPM depending on battery charge (2.2 starter, old one packed in early on)
- Fuel, air and coolant temps on live values seem very reasonable
-- Cam crank sync when it starts - yes and no when it doesn't, but seems totally random when it does it
-- Stores code P0336 with varying RPM (Pics attached)
I've read countless threads on here and otherwise over the last year and a half and this is what I've done so far:
- Remove entire engine wiring loom, trace cables to ECU plugs, discovered a few previous bodges, repaired, re-wrapped loom and refitted.
- Replace and reset cam position sensor, both new and old behave the same
- Replace crank position sensor - both new and old behave the same 396 and 397 ohm respectively resistance
- With ignition on at Crank sensor plug I get 2.37 volts on both pins ( Is this correct? I assumed its just sense but I may be wrong)
- Check continuity of wiring to crank position sensor from ECU plug - all good and 7 ohm resistance
- Check earth straps from battery to chassis and gearbox (0-1ohm), cleaned both anyway
- Check earths out of loom under passenger headlight, (0-1 ohm), cleaned all anyway
- Absolutely no EGR system (Cooler, bypassed at exhaust manifold with plate and welded up intake manifold side)
- Removed fuse box by battery, inspected, checked all fuses - no visible damage, no water ingress, all fuses OK
- Removed BSI under diagnostic plug by steering wheel - no visible damage, burns, water ingress, all fuses OK
Absolutely stumped so far so have a few questions:
If I'd bought the wrong crank position sensor ( Bosch type ) would the engine ever start and run?
Whenever a code such as that is stored on your ECU, when reading with Lexia do you also get such funky values? (Values like this only when reading the code, at live values screen everything seems to check out)
Should I be getting 2.37 volts at both pins on crank position sensor?
What part does the BSI play in starting the engine? Sometimes it seems like I get two clicks from a relay within the BSI when turning key through ignition to start and it seems to not start then but I may just be confused, seems like it's only a single click when it works? (Potentially, not sure if I'm going mad at this point
Have dealt with this for quite a while but it's honestly getting tiring - not just being unable to use it like a normal vehicle, but also not being able to solve the mystery
Hoping you fine gentlemen have some ideas I may have missed!
Thanks for reading and best regards,
Tod
)Have dealt with this for quite a while but it's honestly getting tiring - not just being unable to use it like a normal vehicle, but also not being able to solve the mystery
Tod
