3 persons in a 1997 2 Drs Delivery Van (Holland)
Hi,
I am new here. I am the proud owner of a 1997 Dutch 2 doors delivery van. I would like to travel with 3 persons in this van, to play with my band. As far as I know, there are no 2 seats banks available for this van (only from 2008 up). Are there any solutions, that are easy, cheap and safe ? Can anyone help me with this ?
Thanks in advance.
Vincent (Holland)
Hi Vincent, have moved your thread to the correct location (M49 vehicles) - there was a car version of the van so the rear seats and seatbelts should be able to retro fit from a 1996-2003 Berlingo car.
  • Vincent J'Hollande
Well Vincent, it will be worth checking with your insurer and the local vehicle test station that such changes are permitted. If there is no easy exit from the van - ie easily accessible doors that open from the inside, say in the event of an accident or fire then it's likely that it would not conform.
Here in Ireland I had some trouble by having a seat removed from the rear row - as the reg docs show 5 possible passengers/seats/seatbelts and the conversion I have has only 4.... each time at testing there's a fuss & confusion but eventually I get a pass ticket.
I've carried people in the cargo area of my old van before - years ago.  No seats required!  Not particularly comfortable, but OK for short distances.  Not sure of the legality of it, but if it's allowed then all part of the gigging experience!
(05-09-2022, 08:33 PM)oilyrag Wrote:  Well Vincent, it will be worth checking with your insurer and the local vehicle test station that such changes are permitted. If there is no easy exit from the van - ie easily accessible doors that open from the inside, say in the event of an accident or fire then it's likely that it would not conform.
I 2nd this...
This might be easily done but could change "Conformity" being a van for 2 persons max and so give serious problems in case of some accident or such...
considering the need for a full seat & seatbelt at minimum (but most likely floor is not ready to receive such extra seat neither)
No idea bout budget, but you can find B9 versions with 3 seats close to €6000 easily these days (on .nl websites)
within 5 mins i found a 2015 for 7.5K and a 2012 for 6K
might find for less if you took some time... considering most parts are rather easy to find  you might even go for 1 with small damage (but making the price go down too, yet being easy to fix once needed/budget
The wheelchair M49 I saw in a breakers had 1 extra seat in back if I remember right so is possible to get a rear single seat. Just the hassle with vehicle conformity / insurance
How to change your username
Last Post: Mike
Today 11:04 PM
Power Steering gone - reservoir full, hoses and ...
Today 07:13 PM
» Replies: 19
Spot the Berlingo(s)
Today 12:20 AM
knocking from rear
Yesterday 04:59 PM
Last Post: Andhall
Yesterday 04:59 PM
An alternative to Diagbox - Topdon Artidiag 800B...
Last Post: swawp
Yesterday 09:41 AM
» Replies: 26
Berlingo 07 won't engage 2nd gear
Last Post: Kyleonsite
14-01-2025 08:28 PM
wipers
14-01-2025 06:17 PM
Last Post: xavier988
14-01-2025 10:23 AM
footwell fan
Last Post: de62
13-01-2025 10:13 PM
