Earth and ingition live locations
Is there an earthing point nearest the drivers foot well/centre dash? I know there's one at the front of the passengers door
Is there a chance of finding a Ignition live in the boot of the passengers side or will I have to run over to the divers side 12v boot socket?
There's a steel plate possibly with earth points behind the awkward to remove end panel of the dash at the drivers side.
Btw the rear 12v socket comes directly by from the BSI and gets shut off with the ignition, though it works constantly when running / ignition on. There will only be BSI wiring back there apart from a towing interface feed which could be ignition controlled and is white I'm sure, but opposite side of the rear socket.
It looks like splicing into the earth on the 12v lighter socket when I tap into the live is the way to go. My 12v socket is already after market using spade connectors I'll just take those off and re-crimp in the splice there. I got the idea to run a wire to a 12v +/- electrical connector block with a fuse on the + side in a more accessible place from peugeotCitroen2CV when he was doing reversing cam/towbar to save pulling the dash apart. I'll use a wago connector though.
Can I tap into the 12v in the rear socket? Is White positive, yellow/green negative. I'm installing a reserving camera but rather than wiring into the reverse light I want it to stay on while the engine is running as rear visibility is poor with the window tint, bike rack and a bike loaded inside.
Yep, that's exactly what I did. Green-yellow is an earth everywhere you see it, and the white is the ignition + wire. My rear camera goes to a mirror mount monitor (looks like another mirror until the ignition turns on) which then gives me a constant rear view as I have steel rear doors. My camera is integrated into the brake light and is powered from the rear 12V socket.
I also use Wago connectors as they are the best there is. I'm a controls engineer so I use them at work for some stuff.
  • smtk
(07-09-2022, 12:41 PM)Zion Wrote:  Yep, that's exactly what I did. Green-yellow is an earth everywhere you see it, and the white is the ignition + wire.
Last bit of wiring today and I was stumped to see rear 12v has White, Green/yellow and Green wire going to it. What's the green wire for?
Also is there a trick to getting into that fabric wrap they use on the wires?
Green is illumination wire for the ring. Just use the white and green/yellow and stop worrying about what the green wire is for!
If you got 12v and ground, you did it. That's it.
Fabric wrap, use scissors!
Cool thanks for the speedy reply.
No worries!! Sorry if that sounded curt, wasn't meant. I think the green wire is a throwback to the older style socket with a coloured light ring that lit up when the lights are on, but not used now.
(10-09-2022, 08:46 AM)Zion Wrote:  No worries!! Sorry if that sounded curt, wasn't meant. I think the green wire is a throwback to the older style socket with a coloured light ring that lit up when the lights are on, but not used now.
No no thank you, I have no idea where to start with out your help saved me a fortune in books or asking an automotive engineer Big Grin
I finished up today everything works, really happy to get it all done. It was one of those jobs that spiralled into a lot of "whilst I'm in there" jobs. I took some photos and I'll share later once put away my tools and vacuum all wire ends up.
Brilliant!!! Get some pictures up. I love to see someone get what they wanted to achieve. Sorted!
One thing after another
Yesterday 09:01 PM
12-11-2026 10:41 AM
» Replies: 16
12-11-2026 10:15 AM
Last Post: Dyane6
02-11-2026 11:10 PM
